Choke? We don't need no steenken choke, jus' pump da pedal a couple dozens times while you smoke a cigarette, thas all you need ta do eh?Think back how many old cars in Canada would start right up in -20 with just a choke. Start it up and run back in the igloo for 15 minutes.
Back in the 80’s a friend and I each had VW Rabit Diesels. Those damn things would never start after setting out all day in temperatures less than 20F.
I had a '74 Triumph Spitfire with a 4 cyl and it came stock with a manual choke, as any proper auto should.
That car, to this day, remains the fastest starting vehicle I've ever owned or seen. Hot or cold (with a bit of choke) it would start seemingly with 1/64th of an engine revolution when you hit the starter. You couldn't bump the key so little that it wouldn't start. I never drove it in the Arctic Circle, but I bet it would start there too.
Running only water when very cold is a shaky deal. You MUST block off the radiator because it's possible to freeze the rad while the thing is running
I've junked out 3 Mopar engines that were froze due to no antifreeze
One was a commando 273. The heads and intake went onto another engine. This was way back around 76
The other was a 335 hp 383. At first I thought it was OK because the oil looked good. So I got a hose and started filling....and filling.....and filling. I finally stopped an pulled the intake. Block was cracked inside the block valley area.
Cool story.
Did they mention anywhere in the videos the oil grade?
In 2015 a couple of the full size jeep guys made videos illustrating super low temperature differences.
Test 1: Three Synthetics vs a Conventional.
Amsoil Signature Series 5W-30, -51 C Pour point on data sheet
Mobil 1 High Milage 5W-30, -39 C Pour point on data sheet
Royal Purple 5W-30
Walmart Supertech 5W-30 (Conventional)
Test 2: two more synthetic 5W-30 and a 5W-40
Amsoil
Mobil 1
Castrol Edge 5W-30
Walmart Supertech 5W-30 (Synthetic)
Rotella T6 5W-40
Block heaters used to be common in New England. maybe still are.
Engine oil isnt the only oil to be concerned about at low temps. But thats another story...
Nice catch. Seriously I think its a good observation. I don't think the Walmart conventional oil would have done noticibly better but it probably would have done a little better with the same size bottle opening as the other three.The Walmart oil had a smaller pour throat. The other bottles had a larger mouth on the bottle. Maybe they should have pierced a small air hole in the bottom of the bottles.
You coming to the picnic Saturday?Nice catch. Seriously I think its a good observation. I don't think the Walmart conventional oil would have done noticibly better but it probably would have done a little better with the same size bottle opening as the other three.
Yes planning to.You coming to the picnic Saturday?
I still love 20w50 Racing oil. I was smart enough to follow temp recommendations and run 10w30 in 0 down temperatures. I won't run anything lighter than 10w30.This is for all you 20/50 lovers
