what headers are these?
joshua dewitt
tucson, az
i picked these up a while ago, was told they were on a 69 a body, small block , they slip appart, once i remove the rust with a torch, for fit, and #1 tube runs straight doen not back and over, any clue guys?
They kinda look like Hookers 1 3/4 tube header, but they arn't Hookers.
The tubes look small, 1 5/8?
Hooker does make a set of the smaller primary super comp headers designed for the 273. This could be them.
They look like they could be old Blackjack, or Appliance headers. I think the Appliance headers had a 4 bolt flange on the street hook up. I can't see it in the picture, so that's why I said they could be one or the other.
they were on a 69 baracuda with manual steering and a small block. just trying to see if anyone has seen these before? they are ceramic coated, and the outter tubes are a slip on fit design. the right side nis the normal a body header with i believe the back tube is slip fit as well.
look like 67' up a-body hooker super comps to me... i put a set on a buddies car a few years back.
Oh Yeah, I remember these! Bought a set in 1975 to put in my 1970 Dart. I think these headers are Kustom Tunnel Tubes. It took about a week to crush the low bend below the K frame to about half the original diameter.
They look close to the Hooker 5204's that I had on my Dart, but the only tube that is removable on my Hookers is the front one!
That is what I was thinking. Man your showing your age!
