what is a 200mm dif
crazy 340
quebec canada
like said in an other thread Im about to buy 1994 ram van
Id called the dodge dealer in town and ask what is the dif
the answer was a 4.10 gear and a 200milimeters dif
I ask him what the hell it is and he couldnt answer me
it look like a dana 60 but I know there is also a dana 70
that look like a 60 and it aint good for us
I know I will need to cut it but at 500$ for all van it aint to expensive
It's called the Metric system , 25.4 millimeters equals 1 inch so if it's exactly 200 mm it's about 7 7/8 inches .
They came with a 8 3/8 (same as 8 1/4) , 9 1/4 or a D60. I have only seen the D60 in a C-class RV. I think the dealer is steering you wrong.
my 94 2500 van has a 9 1/4. There is an options tag on the bottom side of the hood that tells you what everything is and codes
9 1/4 is a common rear in those. Looks a lot like a D60. Great rear end, but not many performance parts available.
If it has a 410 then it is most likely a dana. The 1/2 and 3/4 ton trucks and vans had 355 9 1/4's
