What is it
zigs
Yakima, Washington
I've been kicking this thing around in the garage for the last 12 years. I know its a molding but to what.
Fire wall , radiator. Has staple holes. ?
Wasn't on car when I got it. Doesn't seem to match anything
Looks like the wiring harness cover that goes on the interior right next to the rocker panel step plate trim cover.
Just under the carpet next to the seat. Protects the wires from the front that run down the side and then into the trunk. Just one side.
Hood to cowl seal.
I've the same one on my Demon. Stapples holes are for the clip claws.
Mine was in a very good shape , but clips were rotten.
As I'm not in USA, original metallic clips weren't available and I replaced them with six european black plastic round clips (Peugeot).
Just had to drill a little hole between the stapple holes.
Perfect fitting.
Hmm, I'm a bit Ignorant, but I Kinda think it COULD Be, if it was found, and not needed, to be one of those things you rivet to a homemade aircleaner base, for a home built fresh air set up
