B3422w5
As it would relate to like an NHRA stocker build.
You asked a question. I didn’t ask for a schooling.
No, that is the discussion where I found the question I am asking. Its a discussion on speed talk with Larry Meaux and others.
That is why I put quotes around it. Was just trying to provide context to my question, I have zero knowledge of this, which is why I ask the question.
Not to school anybody..lol..I know nothing about it.
All I see is a title to the thread and a one line post.
I made my answer on a subject I don’t know the full scope on and then you use the “-“ symbols as to say your quoting someone else from another discussion from another forum.
So you say.
I don’t see it that way but I do see you diverting/deflecting and placing blame on people that may not be here and/or be able to defend themselves.
As far as I’m concerned, those white tags you used are insufficient and your not taking accountability on a post directed at me which was a schooling post for sure.
You honestly have issues guy.
I hope so as well as the topic could be very enlightening.I was reading a post on another forum. I came across that sentence in a post in a thread on there.
I asked what it means, because I didn’t/ don’t know.
To be more clear, I put the whole post up there, which included the sentence I ask about, to hopefully provide more context of my question.
Unfortunately, understanding this simple question seems to have missed its point with you for some reason. Hopefully someone else will be able to answer my question
Maybe someone else will be able to help me answer my question.Naaaaa, I’m good. You just don’t like my point of view.
You just don’t know how to post a question or properly quote someone else. That is what lead this thread the way it did.
Re read what you posted as if it was the first time and not your thread. If anything, it’s cryptic.
Then your second post quoted but not properly quoted looks like you’re schooling me on something. See it from another point of view through a different set of eyes. I don’t have issues! I read it like I see it and that was my point of view. You schooled me.
Do you know how to manually enter quote tags?
You to bro! EnjoyMaybe someone else will be able to help me answer my question.
Have a great night.
FWIWMaybe someone else will be able to help me answer my question.
Have a great night.
; which mentions "spacers", "Dykes", and "metrics", all lumped together as trick rings, for pistons with 5/64ths grooves ; which are, or used to be, somewhat unusual configurations for an automotive engine. Nowadays you just order your custom Pistons for whatever configuration, but, according to the article, pistons have to be, "stock configuration".If you have 5/64" rings, spacers and Dykes, metric or other trick rings are the thing.
EDIT
IMO; the lack of decent punctuation in the above statement could have been better, and that would have made this conversation almost moot. Below, I rearranged it to make proper sense
If your pistons have 5/64" rings; THEN
spacers, Dykes, metric, or other trick rings, are the thing.
I usually try to stay out of his way, imagine that. But the way he treated you, IMO, was totally uncalled for; and then, as you may have noticed, he tries to smooth it over with sugary words.You honestly have issues guy.
And, I agree with this;
He treats me, and others, with the same distain...... and worse.
That’s because you normally disrespect others choices and tout your own superiority while lightly calling others stupid for the choices they make while not helping with there endeavors.And, I agree with this;
Thank youHe generally seems alright to me..lol
My apologies.That said, it seems as the evening gets late, he seems a little rougher to deal with.
Me too.I can only hazard a guess as to why.
Total seal has different coatings for ring faces. Maybe this is what they are refering to. I suppose anything that reduces drag or increases seal or both would be considered trick
I would assume that a thick ring would machined so a thinner part rides against the cylinder walls and the thicker part rides in the ring lands
Atleast thats what I'd do.
Heyyyy, now that’s a thought! Good thinking.Sounds good. It mentioned the ring lands can’t be fooled with, so the rings I guess can.
Should watch vid's of what Darin Morgan has to do to Hemi heads just to gain higher shift rpms.All this stuff gives me more appreciation about what leading edge stockers and superstockers put into their race programs.
Crazy, the details and tricks.
Wonder how much power a stock ring and a tricked out ring these people are talking about difference could be gained.
