cuda guy Well-Known Member Joined Oct 15, 2009 Messages 492 Reaction score 32 Aug 25, 2010 #1 Hi Can anyone please tell me the correct width drum plate to drum plate and spring purch to spring purch of an a body rear. Will a b body rear end fit in a a body Rich
4spdragtop FABO Gold Member FABO Gold Member Joined Aug 28, 2009 Messages 39,964 Reaction score 23,425 Location Ontario Parts Unknown Aug 25, 2010 #2 I just checked a similar post, and the dimensions on my 69 cuda 83/4 are 43" perch to perch, and approx 50" flange to flange
Plaschy Well-Known Member Joined Feb 2, 2007 Messages 334 Reaction score 57 Location Sweden Aug 25, 2010 #3 Maybe this will help
C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 19,183 Reaction score 5,931 Location 92201 Aug 25, 2010 #4 The CORRECT flange to flange width is 52 5/8" drum to drum should be 57 1/8" Perches are 43" That chart that is floating around is a total POS. Here's a good reference http://www.moparts.org/Tech/Archive/axle/16.html Yes, you can put a B body rear under an A with the right offset wheels. Spread the springs or move the perches (best), seen it done both ways.
