bcschief
Used to grease leaf springs on old cars
You got it!Used to grease leaf springs on old cars
Ok the top tool is a brake spoon for Lucas Girling brakes used on 80s thru 99 Fords medium truck brakes F600 thru F800.
Yep.Ok the top tool is a brake spoon for Lucas Girling brakes used on 80s thru 99 Fords medium truck brakes F600 thru F800.
The 2nd tool is a spicer clutch adjuster tool, Toolmanmike you would have sold both of them on your tool truck.
Vintage toenail fungus remover. Must be heated red hot to work properly.
nEVER SAW THEM BEFORE, THANKSOk the top tool is a brake spoon for Lucas Girling brakes used on 80s thru 99 Fords medium truck brakes F600 thru F800.
Glass cutter.
Battery post pliers
YesGlass cutter.
YesBattery post pliers
Key punch
Yep.Key punch
Torsion bar gripper ?
Sorta.Pic part?
Tie rod adjuster
Winner!Tie rod adjuster
