gotdust57@yahoo
- Joined
- Aug 18, 2006
- Messages
- 346
- Reaction score
- 2
what kind of oil is best for new rebuilt engine with cam, heard rotella changed? thanks
gotdust57@yahoo said:what kind of oil is best for new rebuilt engine with cam, heard rotella changed? thanks
:sign6: :sign6: :sign6:dusterdood said:Run the GM EOS supplement on break in, or the Hughes additive. Check out bobistheoilguy, that website is packed full of oil info.
Mike
Mike
dusterdood said:I agree that the VR1 is the way to go. Brad Penn oil is good, too. Made in PA also. These are about $3/qt here. I'd also sugest a straight 30 wt for the 20 minute break in, then go with the 10-30 or what ever you chose.
Mike
PS, DTK-what bad has happened using additives?
DTK said:Not to start an additive war. You do not need additives. Good non synthetic oil already has all you need. Allot of additives create aeration. Air in oil is bad umm kay. As far as flat tappet statement, you are out in left field. The only additive you need for a flat tappet cam is the molly assembly lube the cam comes with. A flat tappet cam is broken in the first 20 minutes of run time. You NEVER let the engine idle on the first fire up. It should be kept between 1800 and 2500 rpm to break the cam in. Let the engine cool and reset tappets. It's done, it's broken in. the same holds true for Hydraulic cam but not roller. The other problem with additives it makes the oil too slippery ( yes you read right). Ok why is that bad? Glad you asked, What does oil do ? Ok it lubricates. It also is a coolant. Most people forget about this part. Like synthetic in a fresh engine is wrong. When oil moves over the crank as an example. It does not remove the heat from the crank properly. Rings do not break in properly. The list goes on. Its your engine do as you please. I built 1500 hp engines without a single additive. Never an issue.
DTK said:Valvoline 10 30. Don't use synthetic crap. Been in all my engines with complete sucess. Except the race car. I run Royal Purple in that. Stick with natural oil, stay away from the fake stuff. ( synpathetic oil )
ted_sweet said:YOU bash synethics but use it in your race motor? makes no sense
