What main jets are these??? Holley 600
Fuel and Air Systems
  1. Houseoffubar
    Houseoffubar Well-Known Member
    76
    57
    Jun 17, 2020
    Puyallup Washington
    Local Time:
    11:58 PM
    image.jpg Hello, I just pulled my Holley 600 vacuum secondary apart and the two main jets are clearly marked “661” not “74” or “68”
    661 on both jets!
    What the hell is this?
    Thanks for any input!
  2. abdywgn
    abdywgn dismantler
    1,498
    748
    Jul 30, 2006
    Darien, Illinois
    Local Time:
    1:58 AM
    they are a close metering jet(?). A something in between but not quite the same as...oh,I can't explain it. I think they started coming out when the "emissions" carbs came on the scene. I'd look thru the Holley catalog/website/pdf for the precise answer.
    • Like Like x 1
    • krazykuda
      krazykuda Well-Known Member FABO Gold Member How-To Section Editor
      55,279
      20598
      Aug 20, 2007
      Orland Park, IL
      Local Time:
      1:58 AM
      The three numbered jets have flow ratings... The last number is the rate of flow... I'm not sure how many "levels" they have for flow, I believe that it's three...
      That being a 661 means that it flows like a 66 jet at the "1" level of flow...
      You would want to match that one with another 661 so they flow the same...
      • Like Like x 1
      • Agree Agree x 1
      • Syleng1
        Syleng1 Karma is real and Life is short... FABO Gold Member
        1,880
        1462
        Jul 5, 2005
        North Franklin, CT
        Local Time:
        2:58 AM
        Huh? Isn’t “66” the actual flow rate?
        I thought (I get it- krazycuda didn’t make the system up) how can you have different flow rates of the same dia hole? I’m lost. Lol!
        • Like Like x 1
        • mbaird
          mbaird mbaird
          6,260
          3113
          Dec 10, 2005
          boise, Id
          Local Time:
          12:58 AM
          I have some with an H after the number ?
          • Like Like x 1
          • 69_340_GTS
            69_340_GTS Well-Known Member
            4,116
            1998
            Jul 11, 2014
            Torrington, CT
            Local Time:
            2:58 AM
            Because of the tolerances of the holes. So in the standard sizes, a #66 = approximately 0.066" diameter. Maybe the hole is .0658"-.0662" or something? But they never checked the actual flow. The "close tolerance" jets like your #661 is supposed to flow exactly what a #66 or 0.0660" diameter jet is supposed to flow. They were used to meet emissions regulations.
            EDIT: I may not be 100% correct here. But you get the idea. It really doesn't matter if you use a 66, 661, or 662 in a pre-emisions engine.
            • Thanks! Thanks! x 2
            • Agree Agree x 2
            • Like Like x 1
            • Syleng1
              1,880
              1462
              Jul 5, 2005
              North Franklin, CT
              Local Time:
              2:58 AM
              OOOOOH! now I get it. Holley is only perfect when its Federal regulated emissions.
              If not Federal.. "what ever goes." Think I saw that on their website one day. LOL!:rofl:
              • Thanks! Thanks! x 1
              • Mattax
                Mattax Just the facts, ma'am FABO Gold Member
                11,175
                7067
                Feb 7, 2013
                Phila. Pa
                Local Time:
                2:58 AM
                Holley Jet numbers are all flow based. You can find two jet sizes with the same diameter bore because the lengths of the bore and the entrance and exit shapes are different.
                A two digit standard jet is allowed 3% variation in flow.
                Three digits ending in 1 or 3 were used by factory calibration, and I too have found H on a jets installed by the factory.
                Three digits were also used for close-limit jets with only 1.5% flow difference allowed.
                Last are three digit metric jets used on model 4360 and 5200 carbs.
                (ref. Mike Urich & Bill Fisher Holley Carburetors and Manifolds HP Books. Holley part No 36-73, 1987 revised)
                • Like Like x 4
                • Houseoffubar
                  76
                  57
                  Jun 17, 2020
                  Puyallup Washington
                  Local Time:
                  11:58 PM
                  Thanks for all the information!
                • MOPAROFFICIAL
                  MOPAROFFICIAL FABO Gold Member FABO Gold Member
                  6,548
                  5492
                  Jun 1, 2016
                  Beach
                  Local Time:
                  11:58 PM
                  That designates high flow.
                  The jet would flow a hair more than rated but not quite up to the next size.
                  I don't know about the 3rd digit, but I'd just assume take the other guys word for it to no real consequence.
                  They've intro'd and discontinued many things over the years, like the anti siphon/anti pull over nozzels.. went from ball to valve pin under the nozzles at the same time...then no brass tubes...then brass tubes...economizer pv's.
                  How old is this carburetor?
                  • Like Like x 1
                  • Houseoffubar
                    76
                    57
                    Jun 17, 2020
                    Puyallup Washington
                    Local Time:
                    11:58 PM
                    I’m not sure the age, it is a 9834-1
                    I will research it a bit more to see.
                    I am planning to put it inside a box for a mild blow through turbo setup.
                    • Like Like x 1
                    • 69_340_GTS
                      4,116
                      1998
                      Jul 11, 2014
                      Torrington, CT
                      Local Time:
                      2:58 AM
                      That explains it even better.
                      • Like Like x 1
