Challngd73
I have a 340 motor date stamped 10/8/70, I assume that belonged in a 71 car. Its bored .60 over. Any work or clearancing need to be done to a 340 block to install a stroker kit? thanks in advance.
It did 2,000 miles ago when my father had it rebuilt. Did not run strong, I believe he used too large a cam with an unrealistic powerband. Builder used a crane cam, I want to use a lunati grind. just contemplating a stroker kit if I am going to be digging into the motor anyways.Bores have good sonic, lifter bores OK, cam tunnel straight?
