Been about 4 months since may last post, finally got most of my engine parts back from machine work, Engine block was bored, and the deck surfaced, crank was just polished and are 10 & 10 under size. They are still working on the head, had to order new guides and springs and some valve seals. Took about 3 days to do a complete cleaning, bottle brushes and a few rifle brushes as well, and cans of brake cleaner.
Cam bearings today, only three, and then set the cam up in the lathe to check the straightness of things. And if everything goes right on to the crank assembly, and then timing chain, you know the rest.
