tekslk
Most pa oils have paraffin in them which will leave deposits here and there, Im in for royal virgin.
Nothing "on the shelf" will have what it needs if it carries the SAE starburst medallion on the bottle. That includes the Fleet (deisel) oils. If I think it needs it I use Not For Street Use VR1, Joe Gibbs, or Brad Penn. If it's a milder cam (running a single spring with dampener or single springs) then a fleet oil like Rotella should be fine after the cam's broken in. Synthetics should be fine too. For those I personally use either Car Quest 20/50 or 15/40 depending on the build.
