Doosterfy
What oil pump would you recommend for my engine. Its a 440 with stock stroke steel crank, Eagle rods, speed pro forged flat tops, a Milodon 7" pan that looks like it holds about 7 quarts. I'm using CNC Stealth heads, a Comp extreme energy 292 solid roller which Comp says works good from 3500 to 6600 RPM, a Torker II and an 850 DP carb. I don't know the bearing clearances but the short block was built by a reputable race engine builder. The car will be driven about 500 street miles a year and be taken to 1/4 mile drag strips 4 to 6 times a year. Oh yea I almost forgot, the oil pump pick up hole in the block has been opened up to the larger 1/2 inch size. I do not want to use the external oil line kit, I'm trying to keep it somewhat mundane looking.
