What pcv grommet for Mopar aluminum covers
Drifterhp
Member
Ca
I have a set of the black mopar sb la covers they have 1 hole in each of them for the twist on caps I want to add a pcv valve what’s the best way?
THEY ARE OVERPRICED ON EBAY , i MADE MINE OUT OF AN OLD TWIST ON BREATHER , U CAN ALSO DRILL THE BLANK SPOT OUT AND INSTALL THE CORRECT SIZE RUBBER GROMMIT AND PCV VALVE FROM ABOUT ANY PARTS STORE -
I drilled and tapped mine , and used an alum fitting for a second pcv valve . A DIFF MATRIAL LEAKED , Had to use alum. on the alum. cover .
