Your lifters are spec'd for use with Magnum heads, right? (meaning they are Comp's AMC lfiters) You will need hollow pushrods for rocker oiling. The important question is what length...And really, the only one who can determine that is the assembler. I would aquire some stock LA ones, and check to see what you have for lifter preload and rocker tip sweep. Then order the length you need.
