Sorry not an a body but a Dodge none the less...
I've asked on "dodge truck" threads elsewhere and get crickets so I thought I'd try here.
85 D150
When I bought it, I left it on a trailer in the driveway for about a month before I unloaded it into the garage. Every time it rained I had a wet floorboard on the driver side. I traced the source as best I could at the time, water was coming in and following the corner between the firewall and cowl. I don't think it could have been leaking all that long/ as this thing is rock solid, usually you find something that had a water leak the floorboards are swiss cheese if they exist at all. I now have the dash out, the cowl panel, windshield, and the heater box out. There is a vertical seam just immediately under the fender/cowl seam that has a ~1/4" wide gap showing. When I pulled the heater box all the seam sealer that was adhered to the firewall/cowl seam behind the heater box just fell out. And inside the cowl on the passenger side it appears that someone on the assembly line was looking for someplace to "finish off a tube" of seam sealer in a spot not readily seen. I discovered this after the cowl screen was pulled. All was Rock hard and falling away just by touch.
I'm talking about the vertical gap at the bottom of the windshield channel. I don't remember anything being near there, as I dismantled it.
Do I just deal with regular seam sealer there? It definitely don't look rotted out there.
85 D150
