MOPARCODY
will do
[QUOTE
It better run 10's on the bottle.
x2 hope to see you at sac. soon if you need help tuning i'll help 11.40-11.20 on motor should be about right that things lightIf it was mine, I'd put a 950HP Holley on it. The current carb will hold it back a bit. No porting to the ede's and that's more of a weight drop than performance upgrade is my guess.
You'll be one and done with no roll bar in the car. It should run 11.20-11.50 NA and in the mid 10's on juice.
I agree about the jetting provided in the kit instructions. If the fuel jet is larger than the NOS jet, it's a rich tune. Something more square and run the fuel PSI the kit suggest will make for a cleaner tune up. Hope you are up on reading plugs and pull some timing out if using juice.
I agree, if it ran 11.6s NA before & you feel it should run faster with the up-grades (less N2o), there is no way it shouldn't be comfortablely in the 10s on a 125 shot.
If you need a baseline to start for the nitrous check out the instructions for your kit on the NOS website...the tunes have been updated quite recently by Monte Smith and I believe under 150 shot they are now square jetted
