NewOrleansCuda
Member
I will be removing the torx check plug to check the fluid in my 7.25 inch rear end. I see that the differential plug is a torx head. what size is it?
Thanks
Thanks
Thanks there is so much crud down there I didnt even look that well! Thanks, one more thing, How do i pull off the pinion nut. I had the car on the ground and e-brake on but i could not get that nut off!I believe you will find that it is an 8 point socket that accepts a 3/8" or 1/2" square drive (i.e., your ratch handle).
