What size tire for a 15" ralley on a Demon?
a34
The Etowah Flash
Etowah, Tn.
Hey Guys,
I have a 71 Demon with big bolt pattern wheels on it. I got a deal on a set of Ralley's with Radial T/A's. I put 15x7 up front with 235/60/15's and they rub on side to side turning. Not much clearance between the top fender lip either.
What tire size should I run on the front? I'd like to know what's generally recommended for front tire size in 15's.
Thanks !!
:burnout:
One size does not fit all, how do you use the car?
Most came with F70 x 14" or 15" ...F70 = 225 X 70
I have 245 60 x14 front and back on a 69 B-Body no clearence issuses but, the front wear like ****...Just too wide
:burnout:
E=a34;1969642659]Hey Guys,
Thanks !!
:burnout:[/QUOTE]
This is my son's first car for high school. So, he'll drive back and forth to that. I'm wondering if a set of 225 or 215/60/15's would work? Thoughts?
I've got 225/60/15's on mine. 15x7 cop rims, 4.25" backspace. No issues, and my car sits pretty low. I could go wider, but not much taller without hitting the bottom corner of the fender.
I have also got a set of cop wheels on my Duster. I went with 215-65-15.
I was concerned that any taller could damage the bottom rear of the front fenders. I don't know how much wider is possible.
C
Put the Radial T/A 225/60/15's on the Demon last night and the front tires still rubbed. Didn't get a chance to see why, will investigate today when I get home. Dang it !
Looks like it wasn't the tires afterall. One of the fenders had some previous damage and was sticking the tire. I was able to pull it out.
