74 DART'
Looking at buying a pair of 15x4 inch rims for the front of my 74 Dart. What size is everyone using ? 1658015 I think is what I had years ago.
Funny thing. I have tiresize.com bookmarked on my phone.... and they say a 165/80x15 doesn't exist! Lol.
Tiresize.com says they don't exist either.One my street cars I ran a 185/80 15, I believe they were made for Volvos. I found that the 185 had better street manners than the 165 on wet roads.
Thank you very much for the info. I went ahead and ordered a pair of Nexen brand through work. Only ones we could get. I’ll see in a few days how they look. Think they were $90 something a pieceTiresize.com says they don't exist either.
Summit sells some, made by Coker, even have a redline on em. NOT cheap! ($282)
(They did get a good review from a Porsche 356 driver)
185/65x15s available everywhere, I put a pair on 15x3.5 centerlines. Decent tire, but real short!
EBay motors shows at least two brands of 185/80x15s, as little as $51ea.
I've got a couple Nexen 165s holding up the front of my 55, temporarily, at the moment. Came off my Opel. They won't be staying on the 55. Decent tire. I think I paid around $50ea, pre-bidumb.Thank you very much for the info. I went ahead and ordered a pair of Nexen brand through work. Only ones we could get. I’ll see in a few days how they look. Think they were $90 something a piece
Nice 55. Yeah hopefully these tires work out good. Not going to be a corner carver anyway. Just an old hot rod cruiserI've got a couple Nexen 165s holding up the front of my 55, temporarily, at the moment. Came off my Opel. They won't be staying on the 55. Decent tire. I think I paid around $50ea, pre-bidumb.
Thanks for all the information. Wasn’t sure how tires were rated before. I figured the change was from bias-ply to radialThe original metric size was 165-15 which replaced the 600-15 original sizing. These were the oe tire size for the VW Super Beetle. They came out in 1971, equiped with the new McPherson strut front suspension.
The standard bug wore 560-15 or 155-15 sized tires. The max load rating was a little over 1,000 punds per tire @ 32psi. This was about 400 pounds per tire less than the cars original tire size.
The early tire sizing system did not generally give aspect ratio numbers, just the section width and rim diameter. The average aspect ratio on the early tires was 75-83%. Later replaced by 75, 70, 60, 50 % ratios in the late 60's, 70's.
Very little contact patch area, so very dangerous when hard braking. As well as overloading the tire.
The true race cars of that period used the old 855-15 sized tires on the front of the stock, super stock cars as they also had very little contact patch area but were much large in diameter to give more roll out at the start and had a lot more load carrying capacity as they were the load equivalent of the H sized tires used in large sedans.
