jose65cuda
Thinking maybe will be replacing my Grandson 66 Dart 6 cylinder and replacing with a 68 340. So question is what all will i need to make this happen.
Some of these parts are hard to come by so you may want to post an ad in the Wanted section. If you found an inexpensive v8 doner car you could sell the remnants here.Wow almost need a complete donor.
I would add that you need that engine complete, with all the brackets and pulleys too, air cleaner to pan. Also, gas pedal and bell crank assembly, complete exhaust system that will work with a 340 in that small engine compartment, and after that, you'll probably want to upgrade the brakes and rear axle to heavier duty stuff before that 340 gets you in trouble!Here goes : v-8 motor mount brackets , v-8 center steering link , v-8 throttle cable , v-8 tranny , v-8 T-bars (optional) , v-8radiator , v-8k k.d. link . Go get'm !
I didn't realize I had so many PM'S Cleared someif you clean out your pms, I might be able to help.
Have you ever tried this manifold on the drivers side?start searching for a pair of 64-66 A body 273 V8 motor mounts. only need to add a couple of washers when bolting up the one mount (I forget which engine side) & weld a small triangle piece onto the other mount (that info is posted somewhere here on FABO). A '66 & up V8 904 trans (for your rod type shifter linkage as opposed to the early cable shifted). the guys here have covered everything. the best manifolds are a 68-70 340 ex manifold on the passenger side & a '92/early '93 ex manifold on the drivers side. source a "392" center sump oil pan/pickup (middle one in pic).
4 Speed would be nice but my Grandson has not decided yet.what transmission you want to go with?
I must admit that I have not, I take it that it is a no go? EDIT Ebay has 340/360 custom motor mounts for this (no mods needed) and V8 center drag links either one for 3+ billsHave you ever tried this manifold on the drivers side?
i think your talking about the k frame for the early a bodies, center links are differentOn the early a-bodies isn't the center link the same for /6 and v8. The 2 66 darts I had the v8 and /6 were the same
.....again.Up early a rusty
At the hospital all night with the wife. Major neck problems may need some risky surgery. Ug but don’t want to highjack someone thread.
