Science has nothing to do with it. All it takes is a fat wallet.
I want to see him build a 273/292 like Jim's. it seams he posted the dyno sheet and pointed out the lack of torque.Science has nothing to do with it. All it takes is a fat wallet.
Not saying I could but 1.14 lbs-ft per cid ain't too high that would be a 408 making 465 lbs-ft.I want to see him build a 273/292 like Jim's. it seams he posted the dyno sheet and pointed out the lack of torque.
Maybe he can do better.
Was kind of the point of the thread to see what it takes to build more in the 1.35-1.45 lbs-ft per cid.I want to see him build a 273/292 like Jim's. it seams he posted the dyno sheet and pointed out the lack of torque.
Basically torque is per powerstroke (1revolution) & hp is all the powerstrokes over time (rpm).Interesting topic. I think it's more interesting than hp/cut in because you can always head flow and rpm your way to higher power.
I don't have a ton to add here. I would ask, what fundamentally yields more torque? Do that.
Obviously we basically know all the ingredients to do a decent job 1.15-1.30 tq:cid, and vaguely know above that, obviously getting the velocity right (VE%) plays a big role, but beside knowing that don't seem like to many can give a less abstract idea of what it takes velocity wise and other aspects to be more in the 1.35-1.45 tq:cid club.I would also ask, what fundamentally reduces parasitic losses. Do that.
It may be that there's a sweet spot where you get better efficiency between bore stroke and displacement. Put another way, I'd bet that st the extremes you get reduced tq/cu in. So a 273 or a 572 might make lower tq/cu in.
Stating the obvious here, but a cam and intake matched to both make peak torque at the same rpm seems like a big fundamental one to get right.
It takes more than just money.My answer to the original question: 'A lot of $$$$'
Were talking peak torque per cid, it's a measure of efficiency.Question: If a decent running 365 can make 450 horsepower which works out to 1.2329 horsepower per cubic inch. 1.440 x 365 = 525 horsepower. That's difference of 0.2071 horsepower per cubic inch of displacement. Did I calculate this correctly? If so, I don't understand why it would be so expensive to make the additional 0.2071 horsepower per cubic inch. I'm sure that I'm not understanding something here, but it seems to me that the extra power could be had with more compression and cam
If you look at average built 360's they make around 380 lbs-ft to about 450 lbs-ft that's 1.06-1.25 lbs-ft per cid, All out max effort engines can reach about 1.67 lbs-ft:cid, if you getting 1.20-1.30 lbs-ft your doing pretty good. Above 1.35 lbs-ft per cid is a fairly high goal.Question: If a decent running 365 can make 450 horsepower which works out to 1.2329 horsepower per cubic inch. 1.440 x 365 = 525 horsepower. That's difference of 0.2071 horsepower per cubic inch of displacement. Did I calculate this correctly? If so, I don't understand why it would be so expensive to make the additional 0.2071 horsepower per cubic inch. I'm sure that I'm not understanding something here, but it seems to me that the extra power could be had with more compression and cam
I thank you for explaining this to me. It's really a lot more involved than I imagined when going from just a fun car to cruise around in to one that makes some serious power and torque.Were talking peak torque per cid, it's a measure of efficiency.
Basically when you modify your car your re engineering your car.I thank you for explaining this to me. It's really a lot more involved than I imagined when going from just a fun car to cruise around in to one that makes some serious power and torque.
Plus 1.61 lbs-ft per cid.Just to throw a curveball into this, 1963 technology, 3 liter or 183 inches making 500 HP at 10k rpm and 295 TQ at 8500. 12.5 to 1 comp, 112 leaded gas, 2-1.25 inlet and 2-1.16 exhaust valves per wet liner hole, gear driven dual cams on a 102 centerline, pushing flat tappets, mechanical injected, dry sump. Rebuilt every 20 hours. 2.73 HP per inch…. Takes money and the right combo of parts to make the power level your asking for…
That does make sense.Basically when you modify your car your re engineering your car.
When talking torque per cid were basically talking efficiency so for a given hp per cid say 400 hp 318, a less efficient (tq:cid) 318 engine is gonna need more rpms to make 400 hp cause it's making less torque per revolution, where a more efficient 318 can make the 400 hp at a lower rpms cause it's making more torque per revolution but for the most part both are able to make the 400 hp.I thank you for explaining this to me. It's really a lot more involved than I imagined when going from just a fun car to cruise around in to one that makes some serious power and torque.
