What year was this 360 built /
grassy
Nova Scotia
I found 2 numbers....I am guessing aug '79 but that may be too easy.
The 2 numbers are:
8-79-79 and
4179930-860-8
Thanks for your help..
ian.
That would be when the block was cast, not actually built/assembled.
4179930-860-8 could actually be 360-8 ( I couldn't find a casting # list going up that high yet.)
My son actually wrote this down today. 8-19-79 sounds more likely is the casting numbers go month/day/year.
I shall check tomorrow morning.
Thanks
Ian.
i just went and looked...it really could be either but 8-19-79 seems logical..so is this the date I use when looking for parts ?
Will do tomorrow...going to crash now. Thank you for your help.
ian.
sounds like a 1979 engine to me, to make things less compilcated ask for parts for a 1979 dodge D-150 with 360; everything from truck is the same except engine mounts, oil pan sump and manifolds
or ask for a 1979 dodge aspen with 360; everything is the same then...
