What's a '65 ABody Factory Radiator Shroud Look Like?
dibbons
La Paz, B.C.S., Mexico
The '65 Formula S still missing some of the factory A/C stuff. May need to fabricate a shroud. What does one look like, where does it attach, is it one piece or two piece, what material is it made of, original part number? Or is there a detailed thread on FABO I can reference? Thank you.
It uses 4 formed brackets that mount into the radiator side panels that are designed to take the brackets
2 piece bolted together.
It is actually a 6 piece shroud with the 3 top pieces spot welded together, 3 bottom pieces spot welded together then top and bottom bolted together
“dibbons. Post: 1973146438 said:
What material is it made of, original part number? Or is there a detailed thread on FABO I can reference? Thank you.
Made of steel and painted black. I can look up the part number(s) later if need be. Don’t think there’s a detailed il thread (yet)
You're right about that shroud in the pic being bent/tweaked. Also see here.
Part numbers for '65 and '66 A-body V8:
Shroud, upper: 2524 306
Shroud, lower: 2524 313
