The I beam is the best rod overall. The H beam is slightly stronger, but heavier. Heavier means slower revs, less rpms overall, and more stress on the crank and block. That's why the best engines in the world use I beams, but very expensive, very light, and perfectly made ones. OMM is right, the differences in the imported rods is basically the finish machining and quality control and none should be installed without having them cycled and carefullly checked.
The cheap I beam Eagle rods are a light weight stock replacement (the SIR rods). I would not use them in a 600hp application. Nor would I use factory rods. They are simply not designed for it, and over the long term, they run a serious risk of failure. Especially in a stroked engine where the acceleration and deceleration rates of the piston are so much faster. I would either use the Eagle H beams, which are fairly cheap but heavy, or a set of better I beams. As I said, K1 has a very nice I beam rod that's not going to break the bank and the finish quality is very good.
