Whats everyone gona do you their car during the winter?
bamamopar
Owens Cross Roads Alabama
I'm just sitting here wondering what I'm gona do to the old dart this off season. I figure I'm gona get a stall for her and frame connectors. I might even wax her. So what are yall going to do to your rides?
putting a 408 stroker with W2 heads on it. I might even clean it too.
I may do some bodywork on the RF corner where someone backed into me... but I have some 41 and 47 Ford COE cabs I need to get in out of the weather before they rust away so, those take priority.
restore it! anything else would be un-civilized . lmao
I need to pull the drive train as the 727 seems to be slipping.I will be swapping the engine at the same time.I'm currently running a used 360 that runs well but is a bit tired.It will be replaced with a built 360 .040" over .Still working on the rest of the combo.
I think I am going to put together a mild 360 that's been sitting on the stand for 6 years.
I just need to stop with excuses for sitting around.
I need to change the freeze plug that is leaking on the blue 66. Trouble is, its between the bellhousing and the motor. The red 66's trans needs to come out and be rebuilt, it slips so bad I can't drive it. Nella's car still needs the windshield pulled and replaced, and the dash needs to be removed and sent down to Leanna for a powdercoat. The GTX needs to have that trans leak tracked down once and for all or I'm takin' a sledgehammer to it, and the van project just needs to be started, then completed by spring. Other than that... not much!!!LOL!! Geof
I plan on driving the hell out of it! Lol I have a set of weld 15x10 wheels on the way and a set of 325/50/15 hoosier drag radials also. Then time to hit the track for the winter! 10's here I come!
Our winters are in the 70's with no humidity. The perfect time to drive your classics. MMG
I'm going to be in putting new floor pan, new interior, new seat covers, and replace the
7-1/4 with 8-3/4.. And hope I can get it all done before spring..
When the roads are dry I take mine out for a drive. Makes a lot of power in the cold...
its winter in the rockies, so whats that mean ? drive the piss out of it lol
Gonna be pulling the gas tank down. Leaking around the sending
unit gasket. After that the dash comes out...I think maybe
the voltage limiter is bad. No gas gauge and no ammeter worky.
Got to get it ready for the Carl Casper Show in late Feb. in case I go.
Paint on the 66 Dart and a new stoker engine,then put all back together.
On the 73 Dart Sport,new brake and clutch pedal bushings.
On the 68 Barracuda I might redrill for LBP and some Cop rims
Hoping to get modivated next month.:rambo:
68 GTS I hope to pull the engine and auto trans and finish the body work,finish the 4spd conversion.
69 Cuda I will be upgrading the fuel system to feed the crossram,change the T-bars and install the frame connecters
93 Iroc R/T custom build a cold air intake with a spare hood I have for it,like I really need to make this thing faster:glasses7:
