What's the problem with this 1967 Barracuda trunk trim???
Let's go for 4, I think those are actually 73 tail lights from a Camaro.
Here's a 'placemat' wiring diagram I bought years ago for a 67 Barracuda and it appears to be correct, iirc the 68-69 are slightly different, particularly the wiper motor, or maybe it's the other way around.
Thanks again!
I tried to clean the photo up some.
But, it was still not very readable.
So, I purchased a 11x17.
You are aware that a member here made a layered PDF of the factory drawings? I posted a couple corrections or clarifications but his colored and layered drawing is about as good as gets for '67. The assembly drawings are of some help too depending what your doing and how deep yoiur interest.
Now that you mention it...
Probably should look at the date markings in the plastic lenses.
I actually prefer the 68 Camaro look.
Removed the 68 upper amd lower trim panels today from the trunk.
What a previous owner did was simply paint the center area black, using the 68 upper and lower panels.
So, I'll have about a dozen mounting holes that I'll have to have welded in before I resurface and paint body color.
The welds won't have to be perfect; but better than just using Bondo type material to repair them.
Anybody need some 68 Upper & Lower Trunk Trim????
