Hi Guy's,
Ok I have done a few miles with my new motor & my engine builder told me to check & adjust the rockers / valve clearance......(He set them at .019 inlet & Exhaust when he assembled the motor)......
I have a comp cam # 20-633-5. The cam card says the clearance should be .020 intake .022 Ex. When I set them hot I set them at .019 In & .021 Ex & it is now a bit noisier.
I was told that if the clearances are set cold you should take .003 of the required setting has anyone heard of doing this ???
Any suggestions would be appreciated.
Thanks Oz
Thanks Oz
