bricud
Cuda's Cuda
I've been getting my 1969 Barracuda road ready and am looking for some wheel advice. I have disc brake conversions on both front and rear and the front has the 5 x 4 bolt pattern but in the process of changing the rear end I put in some hd axles that have the 5 x 4.5 bolt pattern. I've been looking at wheel options (which are very limited) and am considering ordering the Crager Series 08/61 S/S. That way I can put 15" wheels all around. I am limited to the 15 x 7" up front (smallest with 5 x 4 bolt pattern). This has a 4.1" rear spacing. Is that a problem? Otherwise I would have to go with the 14" wheel up front to get a narrower wheel with 3.4" rear spacing.
On the back, I can put in a 15 x 10 with a 5 x 4.5" bolt pattern. This wheel has a 4.3" offset. Probably put a 255/60 or 265/60 on the rear if they will fit in the wheel wells. Otherwise I can put in a 15 x 8 that has a 4.3" offset but limits my tire width to 245/60 max. Any advice will be helpful.
Brian
Brian
