Wheel stud knurl
limegreen70
Pokorny Enterprise's
Milton PA
What is the knurl size for the 7/16 wheel stud on a 1970 stock drum brake set up? I need to use some longer aftermarket wheel studs. Please and thank you.
Rock Auto...
Example of info they have (front 10" drum)
There is a difference between 9 and 10?
They are different part numbers.
You need to look at the specs of each and see if they are different.
They might have the same knurl but different lengths???? ( just a guess)
The Dorman web site has a downloadable spreadsheet listing hundreds of studs, with lengths, diameters, knurl size and thread pitch. But then you need to cross reference it to the application listings. It’s a good way to check up if you aren’t sure about the details.
