'64 Cuda
I received a new Jegs catalog in the mail a couple of days ago & found this listed in it. It's a tool that simulates a wheel & tire mounted to your hub. It can be used to simulate just about any size tire & wheel, from 15" to 30" in diameter & 6" to 20" in width. It looks like you could adjust for the wheel & tire combo you want to use, then just bolt it to the hub & rotate to check clearances. It also measures bolt pattern, lets you determine backspacing, etc. I checked Summit Racing & they have it listed too. To be fair, I'm posting links to each one. It's also available on eBay.
http://store.summitracing.com/partd...=PHP-01201&N=700+400251+1004+115&autoview=sku
http://www.jegs.com/webapp/wcs/stores/servlet/product2_10001_10002_761153_-1
I would imagine that any good wheel & tire store would have something like this on hand, but I've never seen one before (I haven't been in a good wheel & tire store in a long time either). It's a bit pricy at almost $90, but it could keep you from making an expensive mistake if you're ordering a set of wheels.
:burnout:
:burnout:
