Boris
Member
Need some advice folks. I would like to put 15" wheels and tires on the fish, 225 x 60 x 15 on the rears and 195 x 60 x 15 on the front. My question is what back spacing on the wheels do i need?
Need some advice folks. I would like to put 15" wheels and tires on the fish, 225 x 60 x 15 on the rears and 195 x 60 x 15 on the front. My question is what back spacing on the wheels do i need?4-4.5 with a 15x7
Thanks for responding. I have a 5 on 4" bolt pattern now and i am replacing my rear end with a 8 3/4 with a 5 on 4.5" bolt pattern W/disk brake conversion. I think you are correct about the range not front and back. i wanted to check to make sure.Don't wanna put words in Mike's mouth (gonna do it anyway) but I think he meant a range of 4" to 4.5" of backspace. (NOT offset, thats something entirely different)
I think you with find 4.5 bs on a 7" rim almost impossible to find, other than a custom build.
I would go to summits site, and plug in 5 on 4 bolt pattern, to see what is
available, and check backspaces.
Also, you can reach a specific member by using the "at" symbol, then member name, like this....@toolmanmike
I also have a disk brake conversion for the front and that will put to a 5 on 4.5" bolt pattern. i am looking at putting 15" wheels on it.You'll have a lot more choice in a 4 1/2 bolt circle wheel, but still stuck with limited choice for the front 5 on 4
I don't know if the disc's can be redrilled for bbp. There was a thread here, many years back, on using early mustang rotors to get bbp with the KH brakes.
