khuebner250
So earlier I said I stripped out the vent window pivot on the driver's side. I just found out why. Here is an original to a repop. Little bit of an offset difference.
I'll just keep the 22" opening then. No need to cut her up if there's not that great of a benefit.
Neat idea mate!
Nice job, looks really good, I think I'm going to fight putting in and mounting, adjusting rear quarter glass. Car looks greatSide glass installed, vent windows, door glass and quarter glass. Had to make a new vent window bolt and anchor also.
Do you have a part number for that radiator? How's it fitting.Got my non bent radiator the other day. Opened up the cooler lines from 1/8 npt to 1/4 npt with a .375 i.d. Then I installed some compression fittings for Hardlines. Gotta get it mounted and make SS lines around to the aux cooler.
It's a 26" radiator so I'm still in mock up phase. Debating on cutting the support or just leaving the 22" opening.
AE374 champion. Fits well. I had to put a 3/16" nock in the "L" mount to fit the driver's side frame rail and a couple of new mounting holes.Do you have a part number for that radiator? How's it fitting.
Thank youAE374 champion. Fits well. I had to put a 3/16" nock in the "L" mount to fit the driver's side frame rail and a couple of new mounting holes.
What a giant PITA! If you ever have the opportunity to help do quarter glass in a notchback, don't. Find better friends.
