frederick_76
All I did was a simple oil change on the Barracuda' s /6 after work today. Got it all buttoned up, added the oil, New filter, and fired it up to check for leaks like I do after any oil change. Well the car started to run ruff, it was missing and would die on me. Well, the old filter was on really tight, had to hammer a screwdriver through the filter to break it loose. In doing so I must have made contact with the dizzy and moved it out of time (the hold down was just loose enough to allow the dizzy to move). 2 hours of scratching my head and wondering "What the @$&#", I saw a clean spot on the hold down for the dist. "No F@$&#!g way!!! Got out the timing light and set her back. I was really sweating it for a bit!!!:banghead::banghead:
