buck351
I trying to check to make sure all the main grounds are installed after the resto. I found the one missing from the block to the firewall and replaced it. Made the tach act strangely when it was missing. The battery ground is connected to the block. These two I remember but I read there is another from the block to the frame? If so where is this located?
