I just found this post and it got me thinking. The chart link in post three gives the exact pin height (1.687) that would yield a zero deck if the deck height is truly 9.60. I built the 360 engine I’m initially putting in my dart about 35 years ago with no thought of quench. I’m .050 below the deck but with my shaved J heads at 60 cc, I have a static compression ratio of about 9.5 that I’m fine with. I disassembled the engine for cleaning since it sat for so long so when I get back to my shop Monday I’m going to check the actual pin height of my pistons. Then I can see if there is a step dome with .050 more pin height that will provide better quench with not much more compression. Thanks for the discussion.
