Where do these belong..?
nodemon
St.Louis
These 4 beveled type washers came with some exhaust manifolds and full exhaust I bought... Where do they go..?
Exhaust manifold stud washers. Should be more of them!
There were only 4 when I bought this manifold to tail pipe exhaust.. My first thought was they must be for the manifold to downpipe connection since there were only 4... I just used the 8 bolts and flat washers that came on the engine that came with the car. So, it's incorrect to use flat washers with the bolts..?
Actually, the location could vary depending on what manifolds you have, I just automatically thought of early 340 manifolds. They are held on by a combination of those washers with studs and nuts, or bolts, and some special "sleeved nuts".
Ebay image:
NEW 1968-70 Mopar 340 Exhaust Manifold Hardware Kit | eBay
Just an example-shop around for best price or a set for a different type manifold.
My 67 273 has them on most of the bolts but none of the studs.
There are 7 total.
The manifolds were off the car once or twice So I can't say for sure where they should be, only that there are more than 4 (one on each stud)
FSM to the rescue...
67 sb
1 washer on each of the studs
1 washer on each of the outer most bolts (screws)
Center bolts (screws) no washer.
There are 7 total.
67 sb
Yup- but it all depends on what manifolds the OP has. He never did say.
I would not think there would be any issues using o e on each bolt/screw/ stud as long as there is clearance enough for the washer.
Thought just hit me...
I'm the 67 FSM it shows them being used on the outer screws/studs only.
I wonder if the 2 inner "lock" the manifold in place and the outer ones with washers allow the manifold to "slide" a little due to expansion?
