ChrisRomello
im planning the wiring for my ‘65 Valiant and was wondering where the battery negative normally connects. The battery is in the stock location. Pics would be great! Thanks!
Not unless you ground it or make certain that a ground is in place as indicated by others above^^Ok, is the engine then grounded to the chassis?
On my '64 I have battery to block, block to firewall. I used the additional neg. wire from the battery clamp to the core suport to ensure better ground for the lights. Belt & suspenders!On 1970 and newer mopars they had a smaller wire coming off the negative battery terminal to the core support to ground the body. Then no wire from back of engine to the firewall.
On my Slant with A/C, the ground is connected to the A/C housing. Now you guys have me wondering if that is correct?
