75 valiant
New Member
hello
looking to buy a new 727 transmission does anyone know where I can buy one?
I Custom Build 727 & 904 TF Trans . I am in Greeley Colorado . Where do you live at ? Freight can be high $$ . 727 Weight is 135 Lbs . Without Fluid and Converter .. Street or Strip and Describe Engine ..hello
$450 Plus Parts Required based on Horse Power & intended usage ..I Custom Build 727 & 904 TF Trans . I am in Greeley Colorado . Where do you live at ? Freight can be high $$ . 727 Weight is 135 Lbs . Without Fluid and Converter .. Street or Strip and Describe Engine ..
I live in Massachusetts. My motor makes around 450 horse. The transmission will need to handle the horse power.
There's a problem with the one I'm using now. It keeps wearing down the snoot on the stall converter. I've gone through 4 converts in a year.
Not sure what's causing this problem, but the transmission is the only part that was used.
You never said if s.b. or b.b. and the rest of package !!!are there dowl pins in the engine ? there is something out of alignment .
something is wrong, you do not need a custom converter, how is the fit in the back of the crank, everything in balance?
