Where to get exhaust for 73 Dart sport?
69CoronetRT
Hi. Posting for a friend that needs new exhaust for his '73 340 Dart Sport.
Is there a national distributor for exhaust that will fit his car or do we have to go with a custom local bender?
Does Accurate Exhaust carry a set up and if yes does anyone know approximate cost? He does not want factory correct; just something that will work. Car has stock manifolds.
Accurate should have what he needs, His are stock style compression bent and should work with the stock manifolds. It will probably be around $500
His other option is TTI which is mandrel bent and more performance oriented. It will cost about the same price and they also have kits for the factory manifolds.
Thanks.
Follow up question:
What other manifolds, specifically passenger's side, will interchange with the 73 340?
Are they easy to find?
What should he expect to pay?
Thanks in advance for any help.
I think 71 and later 340/360 passenger side manifolds are the same. You should be able to pick up a pass side for $50
The earlier manifolds probably flow a little better but are much more expensive.
