Where are you guys puttin the hood pins that have 73-76 Darts?
Got a set and dont wanna drill hood and have them look bad in that spot
Pics of hood and pic of mounting spot of the posts under the hood
Thanks Emilio
I installed a 73 Road Runner hood on my 74 Satellite and it had factory hood pins, so I bought a kit from year one and they fit perfect! There was a factory hole for the stud to mount for the pins so it was a bolt on. They look awesome on my car, but they are a PITA! mostly because even after almost 20 years I still pop the inside hood release before I pull the hood pins out lmao :banghead:
Maybe because a GTS's, 'Cuda's, Challengers and RR's were actually available with them installed from the factory? Guess the factory really screwed up some perfectly good hoods.
No guessing on a Challenger, even my '72 has dimples in the fender extension and cut outs in the hood bracing to indicate exactly where the hood pins go...
