On my big-block, I did as nkqkw suggests. I plumbed a 1/8" NPT tee in the oil pressure switch fitting. It is in the same place on a SB, next to the firewall at top of engine, right next to the SB distributor.
On a side note, I would suggest getting the more expensive electronic oil pressure sender. I hate running an oil line into the passenger compartment. Think what a mess 60 psi oil coming out of a broken tube could do. However, my Mercedes diesels have a mechanical oil gage in the instrument cluster and they plumb ~1/4" nylon tube to it. Dripping oil is common in those, but usually from the ignition key which has a vacuum switch for the "stop valve" which sucks in oil when its rubber diaphragm fails. You know that when you get oil on your right sock, plus all the vacuum lines gets oiled. Exquisite German engineering.
