DrCharles
I'm finally working on my '72 big-block Dart again. I originally got the car as a rolling shell so it had no brake lines at all. Now it has an aluminum 2-bolt master cyl. with adapter, '73-up front discs, and 10" drums on the 8-3/4 rear.
I am fabricating all hard lines. The front is fairly easy with a tee, and the rear will run through a proportioning valve which I've mounted on the left fender apron, but I don't remember where the original rear hard line is routed (from the MC to the body bracket above the 8-3/4)...
Looks like it will interfere with the torsion bar crossmember somewhere if I come down the frame rail - does it dip down and around it? Or pass through a hole? Does anyone have a pic or diagram which would help?
thanks
Charles
thanks
Charles
