Pressures don't tell you squat if you don't know a few other things.
If the cabin is really warm, the low side will be higher than it should be, even though it's undercharged.
If it's a "not real hot day," you are doing this in the shade, on "max air" and the cabin gets down fairly cold in temperature, the low side can fool you by reading LOWER that it might, even though it might be OVERcharged. Another thing that can artificially lower suction readings is if the inside fan is running slow, dragging, or plugged, or have some other restriction like heater control door problems.
If the condenser is not getting enough air, due to dirt/ plugged, defective fan, sitting in a restrictive shop, etc etc, THAT will screw up your readings.
