thanks fishy68. the problem that i have now is the driveability. the car drives straight as an arrow with no pulling. the car is real squirrly on the road though. sawing the wheel type stuff. goes in the direction you point it right then. i had it realigned again, and the caster was way off. the guy told me this is for "driveability". this is what he called "memory steer". in other words making a turn an letting go of the wheel, the wheel should return to front and center. mine since the rebuild dosen't have much if any memory steer. the wheel tries to stay the direction it is turned to , so i have to bring it back myself. the sawing effect. i figure the front end maybe still be out somewhere. it is better than before since the second alignment. maybe everything is just stiff and needs time to loosen back some. it drove fine before the rebuild but just tired feeling (little loose) not squirrly. jury is still out on this one
