which fan??
abodyjoe
Berlin,N.J. 08009
which fan would you run? just received my new shroud that should allow a 18" fan. i have these two fans. any opinion on which is better? i have read that the 5 blade moves a bunch of air. its much lighter. thats for sure.
the 7 blade is much quieter supposedly and i would run it.
  1. Blade pitch
  2. Diameter
  3. Number of blades
All go into the amount of air a fin will move.
My 96 Jeep Grand Cherokee has a 5 blade and sounds like a jet going between 1st and 2nd.
  1. Blade pitch
  2. Diameter
  3. Number of blades
yeah that fan noise makes me nuts, all old cop cars and our old chevy tow trucks sounded like a turbo space heater 3 feet from your head
not too worried about the noise. i want the most air flowing.
i have to send the 7 blade out to get powder coated. too ugly the way it is. may throw the 5 on now and see how i like it, then try the 7.
both 18" fans.
Hayden #2947 drive for the -215.
i have the short hayden clutch. i was just changing fans. i'll send the 315 out for powder , i put teh 5 blade onand it moves some air. let it idle in my garage and the gauge moved about an 1/8 inch after 20 minutes.. much better then before.. i will run this 5 blade and if i'm happy with it it will stay.. if not i'll put the nice 7 blade onit.. i will say the 5 blade is so much easier to get to the bolts to put them started..lol
that shout hayden clutch really makes those bolts difficult.
i have the CVF aluminum water pump pulley that is really thick and there is barely any fan riding on the water pump hub... scares me a bit... and yeah.. last time i put the fan on i removed the radiator first, that hayden clutch is not easy
