Which Front fender extension?
j5dart
grafton ohio
I have a 1971 dart that I bought totally disassemled. I am going through all the parts before i send it off for paint and body. I have one fiberglass type and one cast. which one is correct for a 71 or does it matter?
I think either is correct. I say that because, I had a 71 project and a 71 parts car. 1 had fiberglass the other had cast. It may be where the car was assembled that depend on which one the car got. I would think when someone was gathering parts for your car, they purchased one of the extensions at a different time. just my $.02 worth.
Make sure the eyebrow chrome fits if your using the chrome. There is deep and shallow extensions. The chrome is also different for each. There are acually more then two different There is Fiberglass, Then metal with molded studs. Then Metal with threaded holes for studs. and then there are shallow and there are deep in both sets.
Thanks for the input guys, I think i will try to find another fiberglass one to match mine.
What side do you need? I may have a good one laying around.
