twotone68
lifetime mopar man
Soo as not to confuse any one with my question. I would like all your opinions on which heads you think would be a better choice for my combination and goal. This is a add on to my last post . 75 318,85,000 miles on it. mostly stock bottom end, Hughes 318 muscle car cam, melling hv oil pump, cloyes dbl roller timing set.87 swirl port closed chamber # 302 castings on it now. Wieand Stealth intake ,Quick Fuel Hr series 580 carb.carter street mech. fuel pump,mopar elec. ign. with Revonater box,pertronix high out put coil,msd wires. Stock exhaust manifolds,2 1/4 pipes with x pipe and delta flows. This is all in my 68 dart With a 904. B n M rv shift kit, 8 1/4 rear with 3.21 gear. Daily driver. My question is ??? I would like to get approximately 320 hp at the wheels. my cylinder head choices are. Engine Quests, 318B heads with T & D roller rockers,beehive springs,Stainless back cut high flow valves .Or Pro Comps Aluminum Heads with Harlan Sharps Full rollerized rockers. Both will have to have 62 cc because of stock 8.5 compression. I will run The .024 Thick head gaskets to try to keep compression. PLEASE GIVE ME YOUR OPINIONS ON WHICH CHOICE YOU THINK I SHOULD RUN AND WHY !!!!! THANK YOU ALL.
