1973dusterkid
Watch This
Which would be better 1971 J heads 915 stock 2.02 1.6 valves
or
1998 360 magnum heads stock
or
Ooooo-I can't wait to see these responses :happy1:
I'm going with:
The good ones?
good and bad to both...if you're swapping from Js to mags, you'll need different length pushrods, a different intake, correct rockers, arguably new valve covers, different head bolts (or at least the ones that held it down to the engine they came from)...
If the Js are already on the engine, why would you need to swap?
Decide on a short block first,then the question is applicable.....
