Which is Correct
plumkrazee70
Medford, Oregon
I picked up a set of 14'' SBPRally wheels and there was only one trim ring on them so I purchased another "3" but the finish is different, and the valve stem hole is different, however they both fit.
The shiny one with the closed valve stem hole is the one I purchased from a member here, the other came with the wheel.
Which is correct?
